Hey guys,
Do we have any tool like Intel PCM to measure memory bandwidth ? I’m digging into offloading large language models (LLMs) state to host memory.
Thank you.
Hey guys,
Thank you.
There is opensource bandwidth tests, like STREAM, but it won’t show bandwidth in such detailed manner.
I use stream for aggregate bandwidth measurements…
wget -r --no-parent Index of /stream/FTP/Code
I use the arm-cmn watchpoint PMU events to monitor the memory bandwidth of each of the memory channel. This needs the kernel has arm-cmn driver installed. And the command is quite different for different CPU.
Can you share a little bit more like which command did you use ? I really appreciate it.
What’s your platform? Altra or AmepreOne?
This is the command I used for Ampere Altra:
perf stat -C 0 --event arm_cmn_0/watchpoint_up,wp_dev_sel=0,wp_chn_sel=3,wp_grp=0,wp_val=0xffffffffffffffff,wp_mask=0xffffffffffffffff,bynodeid=1,nodeid=16/ --event arm_cmn/watchpoint_down,wp_dev_sel=0,wp_chn_sel=3,wp_grp=0,wp_val=0xffffffffffffffff,wp_mask=0xffffffffffffffff,bynodeid=1,nodeid=16/ -I 1000
up counter is for memory read, and down counter is for memroy write. The fomula for calculting the memory bandwidth of total 8 channles:
read bandwidth(GB/s) = (watchpoint_up counter) * 32 * 8 /1000000000
write bandwidth(GB/s) = (watchpoint_down counter) * 32 * 8 /1000000000
There is a tool called mbw, which does exactly that, using 3 methods, memcpy, dumb and block copies. It’s in Debian under the same name, I guess it should be in the other distros as well.
For reference, this is what my M128-30 gives on trixie:
# mbw 1024
Long uses 8 bytes. Allocating 2*134217728 elements = 2147483648 bytes of memory.
Using 262144 bytes as blocks for memcpy block copy test.
Getting down to business... Doing 10 runs per test.
0 Method: MEMCPY Elapsed: 0.10263 MiB: 1024.00000 Copy: 9977.201 MiB/s
1 Method: MEMCPY Elapsed: 0.10275 MiB: 1024.00000 Copy: 9965.452 MiB/s
2 Method: MEMCPY Elapsed: 0.10285 MiB: 1024.00000 Copy: 9956.247 MiB/s
3 Method: MEMCPY Elapsed: 0.10263 MiB: 1024.00000 Copy: 9977.784 MiB/s
4 Method: MEMCPY Elapsed: 0.10259 MiB: 1024.00000 Copy: 9981.188 MiB/s
5 Method: MEMCPY Elapsed: 0.10261 MiB: 1024.00000 Copy: 9979.923 MiB/s
6 Method: MEMCPY Elapsed: 0.10258 MiB: 1024.00000 Copy: 9982.550 MiB/s
7 Method: MEMCPY Elapsed: 0.10259 MiB: 1024.00000 Copy: 9981.577 MiB/s
8 Method: MEMCPY Elapsed: 0.10252 MiB: 1024.00000 Copy: 9988.295 MiB/s
9 Method: MEMCPY Elapsed: 0.10286 MiB: 1024.00000 Copy: 9955.473 MiB/s
AVG Method: MEMCPY Elapsed: 0.10266 MiB: 1024.00000 Copy: 9974.557 MiB/s
0 Method: DUMB Elapsed: 0.08828 MiB: 1024.00000 Copy: 11599.062 MiB/s
1 Method: DUMB Elapsed: 0.08827 MiB: 1024.00000 Copy: 11600.245 MiB/s
2 Method: DUMB Elapsed: 0.08821 MiB: 1024.00000 Copy: 11608.530 MiB/s
3 Method: DUMB Elapsed: 0.08831 MiB: 1024.00000 Copy: 11595.516 MiB/s
4 Method: DUMB Elapsed: 0.08831 MiB: 1024.00000 Copy: 11596.041 MiB/s
5 Method: DUMB Elapsed: 0.08823 MiB: 1024.00000 Copy: 11605.898 MiB/s
6 Method: DUMB Elapsed: 0.08821 MiB: 1024.00000 Copy: 11608.530 MiB/s
7 Method: DUMB Elapsed: 0.08815 MiB: 1024.00000 Copy: 11617.090 MiB/s
8 Method: DUMB Elapsed: 0.08826 MiB: 1024.00000 Copy: 11602.085 MiB/s
9 Method: DUMB Elapsed: 0.08820 MiB: 1024.00000 Copy: 11609.714 MiB/s
AVG Method: DUMB Elapsed: 0.08824 MiB: 1024.00000 Copy: 11604.267 MiB/s
0 Method: MCBLOCK Elapsed: 0.02533 MiB: 1024.00000 Copy: 40418.394 MiB/s
1 Method: MCBLOCK Elapsed: 0.02530 MiB: 1024.00000 Copy: 40475.908 MiB/s
2 Method: MCBLOCK Elapsed: 0.02534 MiB: 1024.00000 Copy: 40404.040 MiB/s
3 Method: MCBLOCK Elapsed: 0.02530 MiB: 1024.00000 Copy: 40477.508 MiB/s
4 Method: MCBLOCK Elapsed: 0.02529 MiB: 1024.00000 Copy: 40487.111 MiB/s
5 Method: MCBLOCK Elapsed: 0.02529 MiB: 1024.00000 Copy: 40493.515 MiB/s
6 Method: MCBLOCK Elapsed: 0.02529 MiB: 1024.00000 Copy: 40495.116 MiB/s
7 Method: MCBLOCK Elapsed: 0.02532 MiB: 1024.00000 Copy: 40440.741 MiB/s
8 Method: MCBLOCK Elapsed: 0.02533 MiB: 1024.00000 Copy: 40431.160 MiB/s
9 Method: MCBLOCK Elapsed: 0.02529 MiB: 1024.00000 Copy: 40485.510 MiB/s
AVG Method: MCBLOCK Elapsed: 0.02531 MiB: 1024.00000 Copy: 40460.875 MiB/s
edit: now I see that you wanted detailed per channel memory bandwidth results, no, mbw does not seem to do that, sorry.
Came here to share Stream - but many folks have already chimed in ![]()
In case from UVA CS department: Index of /stream/FTP/Code
