Arm developer bundle 192 core arm64 AmpereOne ASRock Rack 8x DDR5, 6 x16 PCIe Gen 5 slots, AMD and NVIDIA GPUs just work, no patches. Bundle is on Newegg. 3U, 2U active & passive coolers are on eBay https://www.newegg.com/p/N82E16813140167 https://www.ebay.com/sch/58058/i.html?%5C_nkw=AmpereOne+Cooler&%5C_from=R40&%5C_dmd=2&%5C_blrs=spell_auto_correct https://www.dynatron.co/products?Ampere+CPU+Socket=LGA5964(AmpereOne) https://www.asrockrack.com/general/productdetail.asp?Model=AMPONED8-2T/BCM#Specifications
On my shopping list for 2029. Unless some good v9 systems appear on a market.
Or someone find spare one and send me (but that’s not gonna happen) ;D
I see it is in CEB form factor. Does it fit in a similar case like the ASRock Rack ALTRAD8UD-1L2T?
Bad timing with this huge spike in RAM prices.
I hope Noctua will make a quiet fan like the ones for Ampere Altra.
Same depth as the “deep Micro-ATX” ALTRAD8UD1L2T but wider. Is 12” because 6 x16 PCIe slots. So think about ATX or E-ATX cases, for example Fractal Meshify 3 XL which is what @bexcran uses. ARCTIC makes Freezer 4U-M AmpereOne cooler that is lovely and quiet which should be in retail shortly. I believe supported DIMM configurations are 2, 4, 6, 8 so you’ve some flexibility to get going with less memory.
The AMPONED8-2T/BCM fits in the Fractal Meshify (non XL version) too.
ARCTIC has a 4U-M listed but it’s EOL and supports Altra but not AmpereOne.
The 4U-M Rev 2 doesn’t support Ampere CPUs, but I guess there’s a Rev 3 coming.
Sorry the 4U-M Ampere version is not EOL but there might be a revision of it for Intel/AMD CPUs that is.
ARCTIC Freezer 4U-M Ampere Altra and AmpereOne coolers are lovely! https://www.arctic.de/us/Freezer-4U-M-Ampere/ACFRE00171A
Amazon has these in US, Germany, and UK
https://x.com/JoeSpeeds/status/1997322232658293109
Do they have anything coming for AmpereOne @JoeSpeed ?
