Hello !
I recently started to plug an Nvidia GPU on my ALTRAD8UD-1L2T system and I noticed that the GPU is stuck at PCIe Gen1 speed.
Did I missed something ? Does it ring a bell to you ?
My troubleshooting command:
mapfile -t PCI_IDs < <(lspci | grep -Ei 'samsung|nvidia|micron' | cut -f 1 -d ' ')
declare -p PCI_IDs
for pci_id in "${PCI_IDs[@]}"; do
sudo lspci -vv -s "$pci_id" | grep -E '(^[0-9a-f]+:)|LnkSta:'
done
The output:
declare -a PCI_IDs=([0]="0000:01:00.0" [1]="0001:01:00.0" [2]="0003:04:00.0" [3]="0004:01:00.0" [4]="0004:02:00.0" [5]="000c:04:00.0" [6]="000d:01:00.0" [7]="000d:03:00.0")
0000:01:00.0 3D controller: NVIDIA Corporation AD104GL [L4] (rev a1)
LnkSta: Speed 2.5GT/s (downgraded), Width x16
0001:01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM173X (prog-if 02 [NVM Express])
LnkSta: Speed 16GT/s, Width x8
0003:04:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO (prog-if 02 [NVM Express])
LnkSta: Speed 16GT/s, Width x4
0004:01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM173X (prog-if 02 [NVM Express])
0004:02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM173X (prog-if 02 [NVM Express])
000c:04:00.0 Non-Volatile memory controller: Micron Technology Inc 7500 PRO NVMe SSD (rev 01) (prog-if 02 [NVM Express])
000d:01:00.0 Non-Volatile memory controller: Micron Technology Inc 7500 PRO NVMe SSD (rev 01) (prog-if 02 [NVM Express])
000d:03:00.0 Non-Volatile memory controller: Micron Technology Inc 7500 PRO NVMe SSD (rev 01) (prog-if 02 [NVM Express])
