Altra and memory list
I am going to build Ampere Altra system cheap. So plan is to use cheap, used memory.
So far I found 3 lists of tested memory modules:
Are there any updates to them?
I can get Hynix 16GB DDR4 RDIMM 3200MHz HMA82GR7CJR8N-XN ECC quite cheap for example. But they are not on a list.
Hi Marcin! Here is the Ampere Altra AVL from March 2024 for our Mt Jade reference platform. It is the most complete, most up to date list. Computer manufacturers can also qualify and support additional DIMMs themselves on their computers, which is why you might see a few additional DIMMs in their lists.
SK Hynix does very well in our internal testing. We have qualified and support 14 different SK Hynix DIMMs for Ampere Altra.
HMA82GR7CJR4N-XN is in the AVL list
HMA82GR7CJR8N-XN is not in the AVL list
My experience has been that memory in the Ampere Altra AVL works on all Altra computers. I’ve seen memory in the same family also work but no promises. The happy path is use memory listed in the AVL.
If you care to say, which motherboard are you using in your build?
which motherboard
Are there any sensible options other than Altrad8ud-1l2t? Not seen them (at least not in EU).
March 2024 list has exact same list as January 2023 list.
DRAM populated DIMMs:
  SK0 MC0 S0: RDIMM[ad:80] 16GB 3200 ECC 2R x8 RCD[32:86] HMA82GR7CJR8N-XN
  SK0 MC1 S0: RDIMM[ad:80] 16GB 3200 ECC 2R x8 RCD[32:86] HMA82GR7CJR8N-XN
  SK0 MC2 S0: RDIMM[ad:80] 16GB 3200 ECC 2R x8 RCD[32:86] HMA82GR7CJR8N-XN
  SK0 MC3 S0: RDIMM[ad:80] 16GB 3200 ECC 2R x8 RCD[32:86] HMA82GR7CJR8N-XN
  SK0 MC4 S0: RDIMM[ad:80] 16GB 3200 ECC 2R x8 RCD[32:86] HMA82GR7CJR8N-XN
  SK0 MC5 S0: RDIMM[ad:80] 16GB 3200 ECC 2R x8 RCD[32:86] HMA82GR7CJR8N-XN
  SK0 MC6 S0: RDIMM[ad:80] 16GB 3200 ECC 2R x8 RCD[32:86] HMA82GR7CJR8N-XN
  SK0 MC7 S0: RDIMM[ad:80] 16GB 3200 ECC 2R x8 RCD[32:86] HMA82GR7CJR8N-XN
SK-Hynix memory from outside of QVL. Recognized once I reseated modules, system booted.
Time to run memtest of some kind.
