ALTRAD8UD2-1L2Q + Ampere Altra Q64-30 + FreeBSD 15.0-RELEASE installer won't boot
I have just received all the hardware I need to assemble my new Ampere Altra based server. I managed to get the rare ASRock Rack ALTRAD8UD2-1L2Q motherboard (with SFP28 and better placement for the CMOS battery) and an Ampere Altra Q64-30 CPU.
All my hardware seems to be recognized just fine, and I managed to boot successfully on Ubuntu 25.10 desktop.
However, my operating system of choice is FreeBSD, and I was hoping to install that directly on the hardware. Following the usual procedure I’m accustomed to from Intel machines, I downloaded FreeBSD-15.0-RELEASE-arm64-aarch64-memstick.img, copied its contents to a USB thumb drive, and tried to start the installer.
I do manage to get into the boot loader just fine, but then it’s consistently stuck after loading the kernel and identifying some information about the EFI framebuffer. Here’s what it looks like in the console:
\ _____              ____ ____  ____     ___           _        _ _
 |  ___| __ ___  ___| __ ) ___||  _ \   |_ _|_ __  ___| |_ __ _| | | ___ _ __
 | |_ | '__/ _ \/ _ \  _ \___ \| | | |   | || '_ \/ __| __/ _` | | |/ _ \ '__|
 |  _|| | |  __/  __/ |_) |__) | |_| |   | || | | \__ \ || (_| | | |  __/ |
 |_|  |_|  \___|\___|____/____/|____/   |___|_| |_|___/\__\__,_|_|_|\___|_|
 /-------- Welcome to FreeBSD ----------\     ```                        `
 |                                      |    s` `.....---.......--.```   -/
 |  1. Boot Installer [Enter]           |    +o   .--`         /y:`      +.
 |  2. Boot Single user                 |     yo`:.            :o      `+-
 |  3. Escape to loader prompt          |      y/               -/`   -o/
 |  4. Reboot                           |     .-                  ::/sy+:.
 |  5. Cons: Dual (Video primary)       |     /                     `--  /
 |  Kernel:                             |    `:                          :`
 |  6. kernel (1 of 1)                  |     /                          /
 |  Options:                            |      --                      -.
 |  7. Boot Options                     |       `:`                  `:`
Loading kernel...seconds. [Space] to pause
/boot/kernel/kernel text=0x318 text=0xa62b58 text=0x281508 data=0x16b460 data=0x0+0x2c3000 0x8+0x160938+0x8+0x189ef1-
Loading configured modules...
can't find '/boot/entropy'
can't find '/etc/hostid'
Loading splash ok
No valid device tree blob found!
WARNING! Trying to fire up the kernel, but no device tree blob found!
EFI framebuffer information:
addr, size     0x10000000, 0x1d4c00
dimensions     800 x 600
stride         800
masks          0x00ff0000, 0x0000ff00, 0x000000ff, 0xff000000
_
But that cursor never gives way to the familiar <<BOOT>> message that signals a successful handoff to the FreeBSD kernel.
Does anyone have any idea as to how I could diagnose this further?
By the way, it looks like @bexcran somehow managed to get FreeBSD installed on a somewhat similar setup. Did you need to apply any special trick at the level of the boot loader for the installer?
i had success by switching the console from video being primary to serial by pressing number 5 in the boot loader.
Quick update on this. In the end, when I was working on this project a few months ago, I couldn’t get FreeBSD to boot directly on this ALTRAD8UD2-1L2Q based system at all, so I gave up on that and installed Debian 13 Trixie on the bare metal, then used KVM/libvirt to install a FreeBSD virtual machine.
However, I checked the ASRock Rack website today and found that a new BMC and BIOS for this motherboard were released last month: ASRock Rack ALTRAD8UD2-1L2Q - Downloads - Firmware. After installing version 02.10.00 of the BMC and version 2.06 of the BIOS, I was happily surprised to see that I was able to boot into FreeBSD on the bare metal.
Now this experience leaves me wondering if this was a quirk of the older BMC/BIOS firmware versions for this specific motherboard, the ALTRAD8UD2-1L2Q. Either way, I hope this data point might help someone in the community!
