Asrock AMPONE8D-2T/BCM Bundle fails with 8D
Works with 4 (Swapped other 4), 2, and 1 (in A1 or E1)
Never seen SOL output
Standoffs removed? DIMMs warm to touch.
Purchased March 30!
When you say you’ve never seen the SOL output, do you mean even when it’s working?
If so, you can access the SOL via ipmitool:
ipmitool -I lanplus -U admin -P admin -H <bmc_ip_address> sol activate instance=1
ipmitool -I lanplus -U admin -P admin -H <bmc_ip_address> sol activate instance=2
ipmitool -I lanplus -U admin -P admin -H <bmc_ip_address> sol activate instance=3
I don’t think there are 3 SOL instances, but I can never remember which consoles are on which instance, and I think this board does have more than 1.
Redid the Ampere One seating and now starting with just A1 failed, which was my last test before the seating.
