Can Ampere Altra Max + ALTRAD8UD-1L2T support Direct PCIe peer-to-peer DMA from BlueField-3 NIC → GPU memory with below setup?
Setup CPU: Ampere Altra M128-26 (ARM64)
Motherboard: ASRock Rack ALTRAD8UD-1L2T
GPU: NVIDIA RTX 6000 Ada
NIC: NVIDIA BlueField-3
Looks like Ampere Altra uses multiple isolated PCIe host bridges and ARM SMMU enforces strict DMA isolation
Also No routing of peer transactions between host bridges. So GPUDirect RDMA cannot cross those boundaries.
Is that our understand correct? Is there any way to make it work?
Thank you very much
