I am running the Asrock rack Altra Q64 bundle and struggling getting any PCIe devices detected. I have two M.2 SSDs which work fine but I have been trying to add a startech 4 port SATA adapter and can’t get it to detect in any slot. I also have been trying to use a SlimSAS to U.2 adapter for a Soldigm ssd and also can’t seem to detect that either.
I don’t see anything really useful in dmesg but does anyone have any other ideas for me to troubleshooti connectivity?
Debian trixie
lspci outputs all the PCI bridges, ethernet controllers, and my two m.2 ssds, but not my specific pcie sata card
Its a startech, the controller is Asmedia’s ASM1164
SecureBoot enabled
ahci is the correct driver
nothing telling, no errors
the achi driver is loaded though which I verified with lsmod.
I also tried this in all the pcie slots too just in case a slot was being finnicky
Regarding the u.2 ssd, the nvme driver is also loaded but it also doesnt appear in lspci output.
I am using a slimsas to u.2 cable for that and it also does not appear in the bios in the nvme section either. I also tried all 4 ports on the mobo to no avail
To anyone that finds this, I managed to find the solution to one of the problems. I was using a tri-mode slimsas to u.2 cable which was not working. Swapping that with a non-tri-mode cable solved the issue detecting my SSD.
