Accessing Ampere Optimized (AI) Frameworks on MS Azure
If you’re running any AI or ML workloads on Ampere processors, you want to make sure you use Ampere Optimized Frameworks for a 2-5 X boost in performance. Since this free AI software is yet to be added to the Azure marketplace we provided walkaround access via the Azure Community Images gallery.
The tutorial Creating Ampere AI Virtual Machines on Microsoft Azure can be found within the Ampere Developer Center under Deploying Cloud Applications.
The Ampere Optimized AI Frameworks video on the Ampere MS Build site also contains this quick step-by-step walkthrough in addition to brief high-level information on Ampere AI solutions.
Can these frameworks and optimizations also be used on other Ampere platforms, such as the I-Pi Dev Kit? Or are these specific to Azure / MS?
Ampere Optimized Frameworks are by no means exclusive, or even specific to, Azure.
To the contrary, in fact, the only reason for this guide is that setting them up from the Azure marketplace, which would be the most obvious way for Azure users, isn’t available yet. Likewise, they are yet to be added to the GCP marketplace and so we also have a simple walkaround for GCP users.
The software should by all means be platform agnostic as long as the platform in question uses Ampere CPUs. There are also multiple distribution channels already in place. I’d say a direct download for the Ampere AI Solutions site, Artificial Intelligence Inference Performance, is still probably the simplest/fastest. This conjecture is also based on the fact that, at the moment, it’s the channel we see the most downloads from, i.e., remains the channel of choice for most developers out there.
Makes sense, thanks!
