I have this motherboard which is not stable. It has 2.7 OpenBMC and 2.06 BIOS with Altra 64 cores. I cleared the BIOS and now the OpenBMC Web UI doesn’t look to read properly the BIOS configuration.
I want to upgrade to 3.06 and make sure that I will not damage the motherboard. So I have few Questions:
What is the deference between altrad8ud-1l2t_3.06.00.static.mtd.tar AND obmc-bios-altrad8ud-1l2t-3.06.all ?
Base on the documentation the tar file is used to update the OpenBMC Web UI on the server. What the other file obmc-bios-altrad8ud-1l2t-3.06.all (has the bios.bin inside) do? It is updating the BMC firmware or updating the motherboard BIOS? -
Do I need to run both, first the tar file and then the bios.bin (what is the correct order)? Do they need to match so they can synchronized ?
See the attached picture, this is the place to update the tar files as well the bios.bin files.
Lastly, can I revert back to 2.07?
Thanks in advance for any assistance
