Hello all,
We are just starting to think about running an AI Coding Challenge/Contest and were looking for some ideas (or things to avoid).
The goal would be get people to think about Ampere/Arm64 are a good solution vs. running everything on GPUs. They work well for modeling but are too expensive and use too much energy for inference.
- Has anyone done one of these, especially one that helped you learn AI?
- One idea was to start off with an easy challenge and then move to more difficult ones.
- Any ideas on what the challenge should be?
- Any courses or topics that you would recommend?
