Could be that the difference is in the x86 stream 256 use versus the builtin_memcpy on Aarch64.
Arm’s memcpy approach here may be a help:
Also, can you make use of the Arm NEON instructions that are built into Ampere for your use case? They would provide some AVX2 like behaviour and use more execution bandwidth - there are two NEON SIMD units per core - so potentially 256 per socket on Altra Max M128 SoCs.
The benchmark and the hardware are actually both performing as designed. The AmpereOne processor sacrifices single-thread memory performance in order to have such small and low-power cores, The picture changes when you scale up in thread count and also memory footprint. Also, note that this test is entirely L1 cache resident and does the exact same copy over many times in order to generate a performance number. In real applications it’s quite rare to have data that you want to memcpy already sitting right there in the L1. Generally when a memcpy operates on L1 resident data it will only do it once.
The performance gap vs. x86 will narrow (and eventually disappear) as you increase the number of parallel threads doing the memcpy, and also increase the data size to something greater than the 64 KB L1 cache.
Memory-intensive LLM/AI workloads actually do perform quite well on AmpereOne, but it’s necessary to scale out to more parallel threads/CPUs to get there. Using more of these low-cost CPUs will increase the aggregate data bandwidth available to your VM.
I’m fixing the tenstorrent stack so I can use my blackhole with my AmpereOne, so far in certain benchmarks it is as good as the x86 numbers, but on others not as much and I’m trying little by little to see how to cover the gaps, one of the low hanging fruits were the optimized memcpys.
Thank you for confirming I’m not doing anything too stupid on that impl
Memory copy performance is a critical factor in many high-performance computing and systems programming workloads, as it can directly impact application throughput and resource utilization. Understanding concepts such as memory bandwidth, processor architecture, and performance optimization can help developers identify bottlenecks and improve overall system efficiency. Resources such as the GNU C Library Documentation provide useful information about low-level performance tuning and memory operations. I also found this overview of the Software Development Life Cycle (SDLC) helpful because it explains how performance testing, monitoring, and optimization fit into the broader software development process. Careful benchmarking and analysis can help ensure that applications make efficient use of modern hardware resources.
