My Q64-22 system just got stuck at the Geekbench Object Remover multi cores test.
root@voyager:~# lscpu | grep cache
L1d cache: 4 MiB (64 instances)
L1i cache: 4 MiB (64 instances)
L2 cache: 64 MiB (64 instances)
root@voyager:~#
root@voyager:~# ./Geekbench-6.3.0-LinuxARMPreview/geekbench6
Geekbench 6.3.0 Preview : https://www.geekbench.com/
Geekbench 6 for Linux/AArch64 is a preview build. Preview builds require an
active Internet connection and automatically upload benchmark results to the
Geekbench Browser.
System Information
Operating System Ubuntu 24.04 LTS
Kernel Linux 6.8.0-39-generic aarch64
Model ALTRAD8UD-1L2T
Motherboard ASRockRack ALTRAD8UD-1L2T
CPU Information
Name ARM ARMv8
Topology 1 Processor, 1 Core, 64 Threads
Identifier ARM implementer 65 architecture 8 variant 3 part 3340 revision 1
Base Frequency 2.20 GHz
Memory Information
Size 125 GB
Single-Core
Running File Compression
Running Navigation
Running HTML5 Browser
Running PDF Renderer
Running Photo Library
Running Clang
Running Text Processing
Running Asset Compression
Running Object Detection
Running Background Blur
Running Horizon Detection
Running Object Remover
Running HDR
Running Photo Filter
Running Ray Tracer
Running Structure from Motion
Multi-Core
Running Navigation
Running Clang
Performance counter
root@voyager:~# perf stat -B -e cache-references,cache-misses,cycles,instructions,branches,faults,migrations --timeout 60000
Performance counter stats for 'system wide':
4209370077053 cache-references
3059842975 cache-misses # 0.07% of all cache refs
5818489541385 cycles
13814137817381 instructions # 2.37 insn per cycle
1944967360187 branches
1534 faults
89 migrations
60.063086870 seconds time elapsed
root@voyager:~#
