As you all know, if you use the GCC complier, there are a lot of options available to you. This paper explains what works best with Ampere Servers and in September, the paper was updated to cover our newer processors. Check it out:
If you have comments/improvements post them below.
Is there an LLVM/clang one? I don’t see one under Tutorials . I think it would be nice to cover different toolchains and combinations of various linkers and compilers. Would be interesting to see what the most optimal configuration would be in a general setup.
